What changes when you put viper trailing arm on a mountain max, spindles are taller I get that does it change the handling? do I need to change anything on the rear suspension to compensate for the viper arms? thanks dan
bolt on and go, for the most part. yes, some minor adjustments to the rear skid to balance things out. dont be surprised if the alignment marks wont line up on the spindles, just clock them one tooth off.
Backwoods M Max
I didn't have enough thread on my tie rods to clock them out. I cut the bump stops off the aluminum steering arms and ready to go.
