Tom Berry
- Jan 23, 2005
Viper--Any input on which wire to splice into (HOT) under the bar pad?
Thanks, Tom
Thanks, Tom
98srx6
Do a search on this site for heated visor.
John W
- Oct 20, 2004
It's the light blue one . It goes to the brake light
Tom Berry
- Jan 23, 2005
Ok John, I knew what you meant. I am running the sno force visor, red is hooked into blue (tail light) black I grounded to hand warmer ground. As soon as you plug visor into connection lights go dim and guage quits working. If i wiggle the cord (visor cord) at connection everything works but very dim. Sound like a bad cord? Or is my ground not good enough?
I have mine hooked to the High beam switch with a wire tap. It works like like a champ.
John W
- Oct 20, 2004
I connected mine in the same place, red from shield to light blue wire, tail light. I connected my ground at the handle bar block where it bolts to the steering shaft (4 bolts). I've done several this way and not had a problem with any. Usually a dim light means a bad ground somewhere.
Hope this helps
Hope this helps
i use the tail light as well, find a good ground and i think u will be fine.
