OK guys, I have a 84 enticer that Im putting a new track on, and putting the suspension in is kicking my A$$.. Any tricks would help. I cannot even get the front bolt hole even close. I have no problems doing my other sleds, this one is a battle.
bluewho
Put the sled on its side than you can see if it is going into the mount .
tried that, still not in?
DJSOPA
with the sled on its side, swing the rear of the skid down/out. this will allow you to start the front bolt. flip the machine the other way and do the same thing(start the front bolt) then proceed to start the rear bolts you may need to remove the front limit strap to get the holes lined up. or a ratchet strap
After I get the front bolts started, I wratchet strap the suspension in the compressed position, with the back of the sled lifted with a chain fall i put my floor jack with a piece of board under the track and suspension, and then slowly lower the sled down onto the suspension until the bolt holes are close lineing up....then use the floor jack to get the holes to line up while you are down next to the sled....it's a one man operation
