electronic susp. not working
yetti
ny
i have 2006 yamaha apex with electric ohlins rear shock, can't get mode button to bring up shock function on info panel, or adjust shock. was told could be a fuse, where would that be located, please help!!!!
The fuse may be above your chaincase/reverse shifter area, I think it's 10 amp. Not 100% sure on all this since I've never looked at this on a 2006. Also, might be a broken wire to the shock, usually where the wire passes the tunnel, or between there and the shock. These are tiny wires and ice can hang up and tug on them, and if they're not tied down adequately the track can hit 'em and they can get pinched in the moving suspension.
That said, this is the 2-Stroke side of TY, you'll find everything you need about your Apex on the 4-Stroke side. You'll be reading until next winter. You'll have to register there as well, just use your same login info. Good luck!
