The kill switch died out of the blue this weekend. Didn't mess with handle bars or anything just went to turn of the sled and it didnt work. The key still works however. Do those switches just go bad? I took the handle bar pad off and made sure all connections were good and wiggled some wires around and no change. Any any way to test or dismantle switch assembly... Or just buy a new switch?
YAMMYJAM79
You can try shorting out the two wires going to the switch, if the sled shuts off then you know its the switch!
