bnsf205
I have a fresh rebuild top to bottom. Going to use this as a rider for the kids. I got it together and have begun testing it and break in. Starts great other than really cold. Idles great. First run got about 50 mph out of it. Secondary spring is a little soft. Cleaned both clutches. Cleaned airbox and exhaust. It just doesn't sound right and it seems to be working way too hard. Could the clutch spring cause all this? Track too tight? It is hanging a couple inches down when on a stand. I opened it up on the stand and speedo read 95. Is it possible the jackshaft bearing and bogie wheels are holding it back? Also I assumed the clutches were aligned, the carb and airbox are a pain to to fit properly. Everything seems straight body is not bent. Tried a new belt today and burnt it a little. Seemed to run about the same 50 mph and that was it. I didn't want to hold it wot that much today but got it back out of the field before I had any worse problems and loaded it back up. It is stock never bored. It was last run about 5 years ago. Plugs are looking good and I am still premixing 91 for another tank at least. Not sure what else to try stator is also new. Sorry for the long post just trying to paint a better picture.
