The Bender head mod is for triple pipes not a stock viper engine, I take it you are talking about a viper right?? The mod evens out the compression so the engine runs better with triple pipes. I believe the opticool head gasket is a bit thicker then the oem gasket which would lower the compression. Chris (super1c) would know, I believe before he said it lowers the compression. For some reason when I had my viper done the compression is at 125psi across the board. If I remember right I think the number members on here say is 115psi with the opticool gasket. When it comes to running premium gas you should always run it in you're sled. I have a neighbor that is"TOO CHEAP" to run premium gas in his sled. 87 was fine he said.... I don't remember how many pistons he took out, well over five. About every 20-100miles he would eat a piston. Got to love them polaris 600 triples!! LOl
I put an Opticool on my viper in December and it was the exact same thickness of the stock one. So, it can't possibly lower the compression. Super, maybe you had a thinner gasket to begin with? My sled was stock and I specifically measured because some people said they removed a layer from the Opticool (I did not).
Maybe bender changed its thickness but the ones I put on a couple of seasons ago were obviously thicker. Just by sight removing one layer would have brought it pretty close to stock thickness. My comp dropped with the install. I had a stock unaltered head gasket on. I installed this on all three of my vipers and they all dropped exactly the same amount. So not sure why the difference.I put an Opticool on my viper in December and it was the exact same thickness of the stock one. So, it can't possibly lower the compression. Super, maybe you had a thinner gasket to begin with? My sled was stock and I specifically measured because some people said they removed a layer from the Opticool (I did not).
I never did look at the difference between my stock gasket and the opticool. I just remember there being a thread on here last season talking about how the opticool was thicker and lowered the compression.
