MM70001
Hey guys i'm installing digitron EGTs on my 01 MM 700 with Bender pipes What safe egt temps should I expect at half and wide open throttle?
you need to find your own, too many variables in that equation. best way is to read your piston wash and plug colors at given throttle positions to find a baseline. in my opinion there is no "you should see this temp at this range", its not that cut and dry. find the happy spot and adjust accordingly. error on the rich side.
jt specialties
At any given time let's try not to see over 1300 deg fahr.
YAMMIEGOD3:16
half throttle 900 to 1100 to wide 1250-1300. no higher 3:16 (yammie tony)
MM70001
Thanks guys!
