jetting a mtn viper
catt_tracker
United States
I run a single pipe now with 143 mains and 52.5 pilots. what should I change to to run slp pipes with custom stingers to start with? 6800-8000' 0-40 degrees
simply go to slp's website, you will find all the info needed for a baseline. from there its up to you to confirm things are right and make needed adjustments. the phone works well with slp.
