I've had my carbs apart more times than I care to think about and am well familiar with the inner parts and pieces so what I'm about to ask is embarrassing,but in regards to setting the float height I need to affirm my thought in that the higher the setting the more fuel will be allowed into the float bowl? The range for the SRX is like 11.5-15mm and I have the ones in my 01 SRX set at 14mm and the ones in my 98 I thought were 14 but actually were closer to 13mm.The reason I'm asking this question is that I'm trying to sort out what I believe is a fuel starving issue with my 98 on the top end or larger throttle openings.The last few times out I noticed while running down a fast trail or road at around 70mph plus that I'd lose fire on one cylinder but as soon as the throttle was closed up some it come right back,so I think to myself I have a float that's either set too low or sticking closed a bit.Well yesterday after work I got the chance to try my sled after putting the carbs off my 01 on it and while I only got a chance to try larger throttle openings a couple of times I never once experienced the loss of a cylinder so I figured it has to be the original carbs causing the problem.So tonight I opened up the carbs AGAIN and AGAIN found NO blockages or sticking needles but I did find that the floats weren't at 14mm like I thought but closer to 13 or 13.5,and while this seems like a minimal discrepancy I don't know if it's enough to cause one of the carbs to not allow enough gas in for larger throttle demands.
I used compressed air to blow through every passage and orifice and I'm 100% confident that all three are spotless so if it isn't the float height setting causing one cylinder to not get enough gas then what could be causing it?The sled runs fine at lower throttle inputs,starts great actually better than my 01.
Carb settings are:
01 main specs 150,148.8,148.8
42.5 pilots
fuel screws 1.5
jet needle stock w/shim top and bottom
floats were at 13-13.5mm ( now are 14mm)
Carb settings are:
42.5 pilots
fuel screws 1.5
