Fasterblaster
I can't see a drain plug for my '97 600 MM. Do I need to remove some cowling or is there no plug???
Blaster, Look inside your tunnel directly under the chaincase and inline with the axle. I made a huge mess while longtracking my viper. Thought you could just drain through the small recess under the chaincase. Found the plug after pulling the axle.
Good luck!!
Dave
Good luck!!
Dave
Fasterblaster
thanks Dave
Fasterblaster
Ok done deal. That was way easier than turning the machine upside down.
If a guy you knew put too much oil in the chaincase, would this cause all kinds of problems or should be just move on to fix/break something else.
yamamike700
yes
There is a drain plug but it is tricky to get at, my advise, we just flip it in it's side, unbolt the cover and drain it with a suction gun.
yamaholic22
why not just open up the chaincase cover and let it drain out the hole in the bottom of the bellypan, that way while you are in there you can inspect everything, clean everything out real good (because you will never get all the shavings but just draining it, and you can very accurately set your chain tension. You guys feel confident with not inspecting your chaincase everytime you change the chaincase oil?
yamaholic22
why not just open up the chaincase cover and let it drain out the hole in the bottom of the bellypan, that way while you are in there you can inspect everything, clean everything out real good (because you will never get all the shavings but just draining it, and you can very accurately set your chain tension. You guys feel confident with not inspecting your chaincase everytime you change the chaincase oil? A blown chaincase isn't worth it, and its never fun being towed home. The small time difference is worth it to me.
