Hi Everyone,
So the GF smashed the 2005 Venom yesterday. Luckily (i think) I have a 2002 viper with a blownb engine. Can I just stick the 600 engine in the 700 chassis? What other parts should I change over because of improvments during that time frame.
Thanks!
Thanks!
watch out for the cooling system, they are different, red head motors use no stat, no recycle warm up system. The front cooler is different. You should be able to use it still but there is an extra hose you will need to block off and the hose ends are larger on a viper so you will be dealing with that as well. you might run into the mount on the side of the frame being different for the muffler too. watch out for air box venting differences.
