golfclub
im trying to find a means to stop my sled from breaking the front swing Arm in the left lower corner and aam also looking for how many ppl out there are having or had the same problem
should be posting this on the 4 stroke side,this is the 2 smoker forum.Will get better help there.
they need gussets welded on them in several places. Halfbaked coatings does them very cheap and can powder coat them at the same time, or you can do it yourself if you can weld. just make sure it is not twisted when you weld it up.
