rockwatersrx
Will stock primary clutching work with a 50/36 dalton helix with a green or red spring?
Looking for aggressive trail set up but I also want to run well on the lakes.
Any feed back would be great.
bADa$$ SRX
only way to find out is to try it
YAMMIEGOD3:16
over rev bad. 3:16 (yammie tony)
Yeah over rev most likely,you'll want a helix more in the 54/46 or 56/46 range I would think.This is going by what my setup is in my 01 SRX that I got from Mrviper.It's 8DN20 weights with 4.5g in both holes,w-w-w spring,green secondary spring w/54/46 helix wrapped at 70 degrees.If your going to use your stock primary spring then go with a helix with a finish angle closer to the stock 47 degree one,you may be good with the 50 start just go with like a 50/46.The green secondary spring is the most favored one to replace the factory red one with.
