Slow_joe
Has anyone used the Sno-Tek rod end kit and power crank to get rid of the free play in the steering?
you can shim the bushings on the outer ends(add grease fittings while your there) if you have a large vice or press you can tighten the factory rod ends. the bell crank needs the collar ground a little shorter, do a little at a time. the white plastic steering bushings can be shimmed snug
