DWallis
Has anyone had a problem with a residue from the old crank seal like the mating surface was treated with a form a gasket before the two halves were put together? How do I get it off without being overly aggressive? What if anything should I use before I put it back together?
Throttle Junkie35
Take a razor blade and scrape it with the blade 90* to the surface. Or use a scotch brite pad.
Maim
Super Moderator
X2 on above.
mrviper700
VIP Lifetime Member
I hit it with fine crocus cloth, wipe it clean and go.
DWallis
Thanks. This is my first time doing a bottom up rebuild and I'm a little gun shy.
