Riding last weekend noticed sled starting to skip did not think nothing of it. Went out today for ride skip come back and got worse so pulled plug and found pto plug gap closed up. It still run just skipped on low end top end was fine. Before I changed the plug I blew a belt. Put over 80 miles on it in the last two weekends. Bad crank brg but with way I ride I would have explode it by now or suck a pc of something in old belt pc
braindead1684
Try the ol Solder trick and check your squish I would think if the piston was actually making contact she would have blown pretty fast that would be a Ton of slop in those bearings.
