73 sl 292 barn find
matt17
WI
Found a 1973 sl 292 low miles (1,400) I now have spark will not start I s 60 psi too low on compression to run ??Any body know where to find a service manaul print or online thanks
You need a minimum of 90 psi for the motor to try and run. Sounds like the rings might be stuck in the piston.
If your not dead set on rebuilding this thing and just want to see if you can make it run : pour some diesel in both cylinders and give it a few days. It will free the rings and might get your compression up a bit.
At the same time it will swell your seals, although replacing them will be the best long term option.
