A little overrev off the line?
norwegian
Well-known member
norway
Hi
I have a #5 hauck kit (adj weights), with approx 3 grams in the innermost hole and about 7grams in the tip. Black hauck primary spring, and a gray hauck @70 deg. I also have a 51/45 helix, which works awesome. I just have a small problem, off the line it will overrev some, before setteling to about 8100-8200 and then creeping up to 8500. What's the easiest way to correct this?
your most likely just slippin the belt a whisker at the begining, I would try differnt sec springs, like a yamaha green at 80 and work down if you can. I personally never had too much luck with the hauck silver.
I see now that it is actually listed up as a silver. I think the instructions from Hauck said gray. I'll try that, thanks.
