MR.HAPPY
SRX primary springs won't work in a SX primary clutch right???
Rustman
They will, just not right, not enough room for the spring to fully compress. Find a tall clutch cover and you will solve this problem. I believe the part prefix is 8df. They come on srx'es for sure.
MR.HAPPY
Will the covers just interchange with each other?
Just get a SRX cover & put on my SX & start using SRX springs?
Rustman
worked for me, on all my vmax-4's. I'm pretty sure it shouldn't be an issue. Just bolt it on and hammer down.
MR.HAPPY
Just make sure you line up the X's when you bolt the other cover back on.
MR.HAPPY
Pioneer Performance told me today that 97 - current can use the same primary springs...
Rustman
If you try tall cover springs with a short cover you will have problems.
MR.HAPPY
He basically thought I was nuts!
Rustman
My best advice then would be to try it. You won't wreck anything and then you'll have your answer. Maybe you already have a tall cover, if so you'll be fine. What year SX is it? Are there any identifying marks on the cover?
I did this very same thing with a friend of mines sled after he called me to ask if I had a spare spring to replace the broken orange Bender one in his sled so I gave him one with roughly the same numbers as his broken one.He has a V Max deluxe 700 and all my spares are for my SRX's so I was thinking that the V Max had the same tall cover but it doesn't and when he put it in it engaged at like 56-5700.
MR.HAPPY
Anybody have a SRX tall cover they can sell cheap?
