53/41
A couple of bucks
Ogle County Illinois USA
What kind of HP are we lookin at in order to run this helix?
Does anyone recognize the maker?
just depends on the rest of the clutch combo as to how it will work. Big helix is generally used with smaller weights and slower shifting primary clutch. The helix is only part of the clutch set up.
It looks to be a old maxx peformance helix
the 8ab's with 14.5mm rollers should pull that helix with the right springs. see if you have enough stuff to do vmaxjhon's inital set-up using that helix. it was for a 500 twin v-max.
I measured it today & it measured out at 52/43. I think I'll save this for my sons SX6. I have a 8BVFA I'll put on the XT6. My thinking on this one is.....a 52/43 will work better on a triple. The 8BVFA (somewhere @ a 47/42) will be better suited for a twin. It has it's OE 41 degree in it currently.
