Black Bear
How can I determine what needle I am running? Is their a simple method or do you have to measure the taper at a given length on the needle?
Rustman
There are normally identifying marks on them. Have to take them out to see.
Vmax540
http://www.vintagevmax.com/vvforum3/viewtopic.php?f=2&t=1529
-Carb. diagrams
http://www.sudco.com/mikuni.html
http://www.sudco.com/mikuni2.html
http://www.motorcyclecarbs.com/Mikuni_J ... 121C37.cfm
the first number is the series needle, or overall length, the 2nd and sometimes 3rd numbers/letters being taper, and last is revision which states how far up the taper begins.
-Carb. diagrams
Throttle Junkie35
Hey black bear, if your working on your pre 91 Exciters you should have a 6FL68 needle and a 166 P-6 needle jet if your running stock a pipe.
Black Bear
Thanks very much!
