Exhaust spring in the bellypan
norwegian
Well-known member
norway
So I discovered a exhaust spring coming out of one of the drain holes by the front heat exchanger. It's too fat to get out, so I pushed it back in. How do I get it out? Do I have to disassemble the whole sled?
Is that possible? Tried to check out with a wire, seemed like it hit a few walls in there.
I'm guessing it's in the cavity where the sway bar goes through. There are holes in the top of that plate. But you'd likely need to pull the pipes to get at it. If you need the spring and can't get at it just get a new one and forget about the other one. Every sled I've pulled apart has had forgotten treasures in there
I got another spring in there, replaced them a few years ago, and I'm not missing any springs. I guess it can't do much damage in there. Getting the pipes out is a summer project for me, I am still riding now. Thanks, I also suspect the sway bar cavity.
