Looking at a set of heel clicker that are from a RX 1. 40-10Y sts3hc 92-11Y. will they fit a 01 srx? thanks for the help
I don't think they will fit. Different spring too.
I found a set dirt cheep.
A 40-10 set? If you don't mind me asking, how much did you pay for it?
looking at the heel clicker site it looks like they may fit the srx. Yes 40-10 set
40-10 will fit. 4 stroke is like 92-10 or something like that.
YAMMIEGOD3:16
40-10yb were for yamaha two strokes. 3:16 (yammie tony)
would they 40-10Y be to heavy for a srx?
No. Brother ran a set in his viper and we run a set in my dad's venture.
snoprokidf6
A set of heelclickers from a 4 stroke will not work. 40-10 is how heelclicker measures the weight. The weight empty is 40g (arm) and 10g (heel). The 4 strokes use a 92-10, 92g(arm) and 10g (heel). Empty your sled wont pull them. Those are some HEAVY weights and reason is for torque. An rx1, apex, nytro has boat loads of more torque than a two stroke.
YAMMIEGOD3:16
snoprokidf6 great info. 3:16x (yammie tony)
your info on the weigth is incorrect they actually weight the same the 92-11Y is just a part number and the weight distrubution is different than an SRX but will work if for the OP in his SRXA set of heelclickers from a 4 stroke will not work. 40-10 is how heelclicker measures the weight. The weight empty is 40g (arm) and 10g (heel). The 4 strokes use a 92-10, 92g(arm) and 10g (heel). Empty your sled wont pull them. Those are some HEAVY weights and reason is for torque. An rx1, apex, nytro has boat loads of more torque than a two stroke.
Just needs the right weight amout in each hole for RPMS on his SRX
snoprokidf6
learn something hew everyday
This was copied and pasted from the heelclicker manual
You are now ready to tune the Heel Clicker
weights
for your particular
application. The Heel Clicker
weights are adjustable in both the traditional arm
and the
new shoulder. At this time, it is important to understand the nomenclature
of the Heel Clicker
weights. The first number identifies how many grams just the
arm weighs without any adjustment hardware (i.e., 40grams)and the “10" is theweight of the shoulder (in grams) without any tuning hardware attached. The arm
will be adjusted first based on information from your old clutch weight that is
assumed to have been appropriate for your sled.
*** Note*** The RX-1/Apexfour strokes donot calculate the same way. You will find the same weight used for the SRX and Viper is the same as the RX-1and Apex. Through testing we have learned that weight distribution is more important to
performance of the RX-1 than actual weight. The 92-11 is only a part number so do not expect a 103 gram weight in this kit.
weights
for your particular
and the
of the Heel Clicker
snoprokidf6
i'm fairly excited to find this out. now i can put these weights in my mom's apex SE! haha
Once we hit winter again I will be doing alot of testing with them.
A couple of bucks
Went lookin for heel clickers on the web. Found this, although the last update was 8 years ago.
http://www.sledgear.com/hc_tuning_yamaha.htm
