Sideshowrob
So like it says, last week I blew a golf ball sized hole in my Mag side pipe, about 4" from the manifold. The piece was hanging on by a little bit of metal. I put about 100 miles on it the week before with no issue, started it up this day, drove around a bit, and headed out to meet some guys to tell stories and run through the gun. As I pulled up, the sled seemed a bit loud... I had the pipes off in the morning, so I figured I forgot a spring... Which I had. Put it on and went to do a run. Sled was stupid loud and slow. So, once it cooled off I was able to find the hole on the bottom side, by looking between the pipes. My buddy ended up running it to his place and welding it up. I tried it out, then pretty much ran wide open for the rest of the day with no issues.
The only thing I noticed was one spring on the bottom wasn't hooked up. Could that have allowed the pipe to move enough to cause a hole?
