enticer300longtrack
What would you recommend for the best clutching solution for my stock clutch, but the motor has power inc end dump pipes, 12:1 comp ratio, 30 thou squish, 165 lbs of compression, carbon tech reed pedals on srx cages, reed spacers, boost bottle, and I may bore the carbs yet. Looking for the best clutch option, both primary and secondary. I am also running a 136x1.75 track, riding style is burning trails and ditch banging.
