enticer300longtrack
What would you guys recommend? Floats, float2s, walker Evans air shocks, doo hpg piggybacks, walker Evans remote reservoir piggybacks???? What would you run... Some of the shocks listed are 18" long and I'm not sure if I can use those... Stock are 17 I believe
devinzz1
srock are 17" but use a cleavis at one end that goes on up to the bulk head. To use these shocks you will need some sx mounts and go from there. Theres not much hope for 18" shocks fitting to the stock front end
TheYammyKid
Im also interested on this topic, so any other input would be appreciated!
Sent from my SM-T210R using Tapatalk
shaggyzr2
If you want a nice soft riding shock use the XTC shocks.
TheYammyKid
More of an off trail rider.
devinzz1
im guessing he already has an xtc or xt as the sx shocks were around 12" long
TheYammyKid
My model is a XT and still is stock on the shocks
enticer300longtrack
Yes I have xtc shocks in my sx already... I'm a Ditchbangr and want a better set of shocks
super1c
Super Moderator
Just have them rebuilt and revalved to your riding style and weight. They will ride perfect, for under $200. Other wise if you can snag some ohlins or floats off a phazer and use the srx shock brackets.
A couple of bucks
TheYammyKid
I need some more cheaper options!
devinzz1
revalve is cheapest. viper shocks are stiffer valved than the trail oriented xtc ones i believe.
devinzz1
my personal "ditchbanging" setup includes 16" rydefx gas cells up front and an edge skid with a revalved fox ps3 and rebuilt rydefx center shock. you gota remember that raising the front only will negatively affect the handling of the sled greatly. I say before doing anything up front swap out that pro action skid!
TheYammyKid
How big of a paddle are you running?
A couple of bucks
So you need better shocks for less than $200 ??I need some more cheaper options!
A couple of bucks
Have you looked in the PAY IT FORWARD.
devinzz1
1 7/8"
TheYammyKid
Any modifications needed to fit that big?
devinzz1
8t drivers
