motosled
I just picked up a 98 srx700 parts sled and noticed today that the trailing arms are not straight right up to the spindle but rather they turn in/angle a bit about from 5 inches back. Can anyone tell me which arms these might be and why swap them from stock? I also noticed the whole front end sits lower than normal even tho the shock springs are adjusted about normal. thanks, paul
There should be a letter stamped into the front of the spindle tube and that should tell you what they are off of.
look like cheap aftermarkets. not uncommon to have that appearance. theres a reason those are half price vs oem.
Devilin AblueDress!
X2 on the cheap aftermarket, don't see a stamped letter at all and them being black. Looks like you have something else on there for skis as well. The type of mount can and usually lowers the stance.
PZ 1
- Mar 12, 2005
Possibly they are bent? I think they should be straight.
motosled
Thanks for the responses and help guys. The arms aren't bent and don't have the letter designation that Yamaha uses, so yes, cheap aftermarket. I think I am just going to replace the fugly skis with stockers and sell it as is rather than spend the money to return it to stock. Sled seems to run great, just needs a track which I have, so I hope to sell it this fall and have gas money for the season!
