PTO exhaust temp off??
dhonda200
Penfield NY
My sled is a sxr600 and today I was checking my exhaust temps for tuning reasons and found my PTO clutch side exhaust is 40-50 degrees cooler then the middle/mag side. The sled is single pipe and the PTO clutch side spark plug looks leaner then the others so im confused. Let me know your views on this. BTW my cylinder and head temp is all Evan across.
If it was a main seal on the clutch side, I'd think that the temp would be up as well. Fire it up & start spraying carb cleaner. Listen for tone/rpm changes while soaking down the boots,seals,etc,etc.
Manifold gasket??
Manifold gasket??
Thanks for the info guys! I went out and sprayed everything and it seemed fine so I don't think there is a leak and I just cleaned my carbs. I'm starting to think that the reeds are bad so ill tear it down today and see what it does.
