Spark plugs,where to carry them
fourbarrel
VIP Lifetime Member
I'm trying to find a place on my 98 SRX to keep my spare plugs other than putting the holders back on the belt guard,I took them off to try and clean up the cluttered look of it.I used to have the holders riveted to the under side of the cab/cowl,whatever you want to call it,on the spot right above the airbox and it seemed like the ideal spot,out of sight.Unfortunately the holders seemed to crowd down into the spot in the airbox where the air in drawn in so I took them off there.Where do you guys keep your spare plug holders?
On the 98 SRX, is there another spot where another tool kit (box)could go?
I've thought about maybe behind the foothold on the right side kind of like the V Max,I believe the tool kit for them is there.I usually keep spare plugs in my handlebar bag but I'm trying to lighten it up too and I usually have both pockets full as it is so putting spare plugs in them is out.
you could just take the plug holders and pop rivet them to the inside of the plastic trunk pan. then they would be out of the way and stay somewhat dry.
