Sx 700/600 carb size
j5ferry1
Michigan
I have a 97sx 700 that the previous owner overheated and put a 99 head on when he rebuilt. Insted of keeping the carb heat line plugged on the head I want to add heated carbs. So I picked up a mint set of 600... I believe carbs and want to make sure they are the same size before I tear everything apart. Still need to pick up a 99 water pump cover. Anyway I'm obviously planning on switching all jets/ needles ect, when I do the swap but is the main carb body the same size on the sleds? Thanks, -JF
i dug into my tech manuals all show 600 triple 31 mm. now with that said and knowing yamaha, measure them. if you have 33, their probley 700 triple carbs. 3:16 (yammie tony)
Thats what was confusing me; I was looking at the parts microfische and it was looking like both had the same sizes. Makes sense though that the power valved machines would have the 33's? I guess I just lucked out. Measured from Engine side (ID).
