Srx007
Hello, new to forum. Had a burn down end of last season and found an engine from a2002 srx 700. Can I swap engine and plug in 2000 electronics for the 2002 or do I need to swap wiring harness and "brain"??
shaggyzr2
02 will work with the 00 without having to swap any electronics.
Srx007
Sweet thanks
Devilin AblueDress!
If the harness and CDI (brain) are available its worth the work in my opinion to run the DCS (detonation control system) the 02 engine comes with.
Yeah if it were me I'd definitely be doing that.For the DCS.
1999venture
I would Defiantly put the CDI and Harness on then, spending $50 is better than spending $1000+.If the harness and CDI (brain) are available its worth the work in my opinion to run the DCS (detonation control system) the 02 engine comes with.
Yamahasrx700
I have an entire DCS system from an 02 SRX. CDI, harness, sensor,coolant rail, dash light etc. $300 for the whole system
Srx007
Thanks for all the feed back guys. Appreciated. I'm prolly going to be selling, :-( Finally finished rebuild. Had a problem with bender, they lost my order. Ended up calling twice, left messages, emailed twice. They called ME back to apologize but ended up lieing to me that my order went out that day which still took 3 weeks to come in. BTW the engine I found had 3300km after reading, 145 lbs on all 3 cyl. Picked up ENTIRE ENGINE, compete drop in, even came with hoses, lines and ignition coils. 300$ Helped guy take engine out after running there as fast as I could
Srx007
Oh and I would also recommend using Lucas injector cleaner/upper cylinder lubricant/fuel stabilizer. I use in all my small engines and vehicle. Keeps fuel system very clean, conditions seals, provies lil extra cushion for rings, and gives me peace of mind. I tried this in my small car a while back and ended up getting 53mpg highway (old Canadian mileage of which we dont use anymore)
