bADa$$ SRX
Welllll decided it was time to freshen up the top. 6500 miles on her and I decided to do a little preventative maintenance and put new rings and gaskets in her. Ordered all new OEM and took her apart today. The inside looked pretty good I was pretty happy, seems to be running fairly rich tho as you can see in the pic. My question is when you guys do new rings and gasket do you do any break in procedures. That half throttle stuff? Oil in gas? Wire oil pump open? Also what about bleeding the coolant system? Any help/insight appreciated guys. Thanks.
