TheYammyKid
I just bought a new track off of eBay, it's a Camoplast Cobra 121x15x1.375 did I make a good buy? I think I did well, what do you think?
shaggyzr2
What did u pay for it?
TheYammyKid
I guess that would be something needed to tell if it was a good deal or not, I paid $459.99 with free shipping.
shaggyzr2
I'd say thats a pretty good deal, thats right around dealer price, retail is over $600
99srxracer
I think ya did alright. I'll give you $400 for it lol
What are you putting it on?
TheYammyKid
Nah think I will keep it, and putting it on my 1997 Vmax 600 xt. Should be alright the fitment chart said that it would fit.
You will have to remove protectors or it will rub on them.
TheYammyKid
Which protectors
usually on the front of the tunnel cooler.
we just notched the track lugs that would hit on my brothers 02 viper when we put the 1-1/4" ripsaw on it.
Or you can Notch as Maim stated... it will hit the tunnel protectors in the front above the drivers.
TheYammyKid
So notch the track is probably the first thing to do
If you dont want to pull the tunnel protectors, yes you will need to notch the track.
TheYammyKid
If I pull the tunnel protector will there be a possible consequence to doing so, track won't be studded.
As long as you dont stud... there will be no problems to have them removed.
TheYammyKid
And those are located at the front of the tunnel by the drive
They are are square tubes that are riveted to the tunnel from the bumper to front heat exchanger up inside the tunnel....
TheYammyKid
That would be the plastic square tubes that run the length of the tunnel, those are not on my sled and doesn't look like it has ever had those mounted because it has never been studded.
Then you should be all set... some sleds came with them in in you case it may not have had them ever .... and thats right the older Vmax had plastic channels or angles.
TheYammyKid
Ok, will I have to remove the front cooler protector like earlier stated
