Teamyamaha13
looking to find the perfect handlebar set up one that looks good and rides nice. Im running an 02 viper was looking at 6 or 7 inch risers but not sure what bars to get with them. Help?
Search is your friend. Here is mine...
http://www.totallyamaha.net/forums/showthread.php?t=88508&highlight=Pivot+adapter
snoprokidf6
I currently have a 7.5" pivoting riser with stock cables. No issues. Pm if you'd like I may have some RSI parts you'd be interested.
super1c
Super Moderator
http://www.totallyamaha.net/forums/threads/86904-Pair-of-vipers-go-144-quot/page12
Post 117. I used apex bars and powermadd riser system. My bars are from a 07 apex and they are awesome, heaters work great just have to wire in parallel. Mine is a 04 and has the 2 piece throttle system. For my wifes 02 viper i went with the 06 apex bars because the hooks come off and you can slide on your throttle block. The heaters also work awesome but found these have to be wired in a series just like the original viper grips. In parallel the 06 bars are way toooooo hot. If you need any more info on this set up let me know. We love it.
Teamyamaha13
SXRider7Hundo do this bars feel more comfortable to you. My riding style is trails some of the time but ditch banging is where it's at I want something that good for that. Also I already have all the extended cables
livewire_101proof
I did same as super1c, also used the 06 ones. Used it on srx and viper, I don't have much to compare to but was big difference from stock, they set lower though so u will want risers
