bamaxwell17
Will a 02 Viper seat fit on a 02 SRX without modifying it? My seat has a few tears and I prefer the viper dual lights and found one for a steal in my area if it will fit.
B
B
I believe you have to use a viper tank to make it work?
it will fit on your srx but the little bolts on top of your gastank will show where your srx seat used them to attach the cord, if thats ok with you it will go right on. You could always get a viper tank later and swap it on to get rid of the bolts if wanted.
If you could find a 04 seat for it you might like that one better. This is just my opinion but I liked that 04 better then the 02-03's. Don't slide around as much I found out.
YAMMIEGOD3:16
yep, go right on, and looks good to. 3:16 (yammie tony)
bamaxwell17
So I won't need to change the tank or anything it will line right up? I am assuming there isn't any benefit to changing to a viper tank anyways.
Gabutch
I have an '03 Viper seat on my '00 MM and fits right non there. Thing is that I have to wire it in the Viper tail light plug. Does anyone know where the best place to find a cover for these seats might be?
