2001 sx700r Ignition Fuse
remoetmanjc
Syracuse NY
Hi i am posting to see of any common electrical issues in this model. My Ignition Fuse blows usually on a cold start, i also have electric starting option. This is what i have done.
-Tested new fuse 10a - Problem remains.
-Tested new fuse 20a burned some wires then replaced them - fail x.x but i did figure out the wires burnt were from the ignition coil and further up the harness to a connector and fixed all that.
-Rewired a couple connections that may have been faulty and corroded - Problem remains.
- Electrical grease on an connectors i could see - Problem remains.
- New Plugs - Problem remains.
