The skis for my viper 8fe-23711-00-bk are obsolete at this time. Does any one know of a set of good Yamaha replacement skis or a good after market
ski that would fit.
ski that would fit.
Any ski from an apex, nytro, or viper should work. Try and get the bolts with them too, as they may be a bit longer.
I heard some people like the Yamaha tuner skies that came out a few years ago. Local dealer swears by them
up until 2010, the stock Yamaha ski is a direct bolt on replacement for your saddle type stockers. carbides and loops are the same. 2011 eps sleds had a different ski that still works but the loops are different. carbides are the same as I put my take off 2011 apex xtx skis on my brothers 02 sx viper before he sold it.
A couple of bucks
Does this apply to the steelies on a 96?up until 2010, the stock Yamaha ski is a direct bolt on replacement for your saddle type stockers.
I put on a pair of skies off from a 2014 SR Viper. They bolted right on my 02 Viper.
viperking
I have some used stock skis or a set of black simmons dual carbide skis if you can't find anything
only works on a proaction across. the pocket on the saddle less skis is not deep enough for the tss fronts. i did try with a set of apex mountain skis on a vk 540III, but i would have been into the keel as there is not enough room to clear the tss. apparently the new vkpro front ski has a removable part to solve this problem but i do not know how they handle on the trail.
