limiter straps?
Johnnysrx
SE WI
I was told when I tighting up the limter straps I will gain ski pressure and lose weight transfer, is that correct. My srx dosen't transfer worth a shiz so if I tighting up will it transfer even worse? What else do you noticed when you tighting up the straps? Is it something I should do? My back wheels are like 2 inches off the ground when it just setting there? Is that bad? It just doesn't look right???
