780srxgeorge
i'm not a member on that sight.but i'm working on one & the guy said in cold weather something is drawing the batterie down.there is a re-call on the 07's for the ground wire i found out.but it's charging at 14.00 vo's at 3500 rpm's.every thing seems to be working good though.just seeing what you guys might think.thanks
devinzz1
Bad battery....
780srxgeorge
the battery is new he said & it looks like it.
devinzz1
Leave it unconnected for a couple days and see if it dies.
The 4 stroke phazer has a grounding bloc issue as multiple users have had an issue with it. Check the battery as mentioned above but if the battery is good the ground blocs need to be cleaned.
780srxgeorge
thanks guys for the info. every thing checks out. we will have to wait until winter to to see.
780srxgeorge
now a code (81)
will i thought i was done!.after fixing the steering & a oil change & filter now a code of 81 which is the hand warmers
.can i replace w/ after market?.& all so theres a up date on the ECU that it dose not have.the #'s on the ecu are 8gc-00 & he needs 8gc-10 to make it start better in cold weather.where can we get one of thease
.Barnof parts or laneo would be a good place to start for the up-dated ecu. The hand warmer code also occurs when one of the grounding blocks is corroded.
780srxgeorge
i checked the oms and thay are at 0.20oms on both grips.it looks like the ecu are on ebay for around $200.i'll look at ground again.thanks maim,.Barnof parts or laneo would be a good place to start for the up-dated ecu. The hand warmer code also occurs when one of the grounding blocks is corroded.
