600 to 700 sxr?
jlight
Ilion,NY
was wondering guys if a 700 motor will go in a 600 chassis? are the stator and carb and ignition all compatable? My sons needs a crank and got new cylinders and heads and pistons for 600 but got a line on a 700 motor with no stator or carbs. thanks guys
The 700 uses 33mm carbs, the 600 uses 31mm carbs. As long as they are both dual bulb or single bulb versions they are 100% the same. The dual bulb version has a different CDI/stator/fly wheel combo. Your 600 electronics should fit what ever version the 700 is. 33mm carbs should be pretty easy to find and reasonably priced.
