SRX and Viper Side Coolers interchangeable?
CdnSxR6
Ottawa, Ontario
Need anyone with experience replacing side coolers on a Viper. I know the sx have smaller diameter inlet and outlet... Will SRX coolers interchange with the same rivet pattern or should I stick to Viper only?
just did this on my viper, srx yes you can,transplant a 2000srx or newer rear heat exchanger while your at it.wont overheat in low snow conditions!!!and same rivet pattern on foot he,youll have to drill holes for the rear but worth it pipes same diamiter and hooks right in!!
