2006 nytro
Jordantimber
CA
Got a hance to buy an 06 nytro with 4446 miles on it. guy is asking 4 grand for it. looks to be in really nice shape. wondering if its worth it? he says price is negotiable ..
that motor is just broke in. only real issue with that sled (besides the clutch rattle) is that the timing chain tensioners tend to go bad. if in good shape, i would expect that sled to bring between $3000-4000 around here.
you would get more info on the 4 stroke side in the rs section but for around here that is a pretty good price.
My brother rode one for 8 seasons.Positives are awesome power,great fuel economy,sound,easy steering,easy of service.Negatives are weight(even with 36lbs removed you could still feel the mass),rear skid front arm cracking,ski lift(as in SNAP-ROLL,but no where near as bad as a 1990s skidoo S-chassis).Also stock seat breaks the rear heat shield mounts.Just check the rear skid arms,bearings,coolant hose under clutch guard,and make sure when you remove the airbox you reconnect the crankcase breather hose(very important).ty-pic-1.jpg
