700srx
- Jul 23, 2003
Having trouble getting the water pump seal to fit. Have had it in the freezer for 2 hours thinking it would shrink some,but no luck. Any help please!
take a socket the same diameter and bang the seal into place..It is a tight fit but will go back in.
sloTJ
I had the same problem when I replaced mine. I remembered getting the gasket cold so it was a smaller size too but yea I fought with pressing it in slowly in small sections then quickly bolting it on.
700srx
- Jul 23, 2003
Had this in freezer over nite still can not get it to fit.Just no way.
I put a little layer into the groove on the cover of RTV holds it in place then on gaskets like you speak of I have cut a little pc on top side then put little extra rtv over the cut
