Clutch side axle bearing
srx70024
Westfield, MA
What is the lifespan of the clutch side axle shaft bearing ? Had one in my 98 SRX go in 2500 miles, my buddies Viper appears to be gone after 1700 miles.
Others... ?
Thanks.
5600 miles and still going....
I grease mine after every ride (500 miles or so). Pull the secondary, pry off the cap of the bearing and work grease into it. I do both sides. Do this also to the speedo side bearing and they'll last as long as you own the sled.
Jon
