1997 SX 700 vs 600
Yamahasrx700
Channaho, Il.
What is the chassis difference between the 600 twin and700 triple. I need a new chassis for my 700 and have a line on a good 600 twinchassis.
Ron
chassis are identical the only difference is the motor mount placement all you have to do is drill out a couple rivets and move the mounts to those holes. I did a motor swap on a 2001 sxr 500 and put a 700 triple in its place. also there is no rear exchanger on the twins just the front one and the running boards. i would find a srx exchanger for the rear for better cooling.
