Pioneer performance (716-496-8800)has shock extensions for ohlins front shocks for sx and srx improves ride and 1" drop out travel48.95$ they also work excellent with there sx,srx long travel rear suspension kit 98-99sx,srx 329.00$ 00-02 srx 319.00$ cheaper than maxxperf.i have this set up on a 98 sx 700 and it is awsome
ReaperSRX
I hope i have the same results, i put a set on this fall and can't wait to try them, what kind of clicker setting are you using, the # from 0 (softest)..........Reaper
ohlins shock extensions
well i set mine at 10 clicks out, the standard is seven out on a sx.but if you have srx so im not sure what the setting for standard is on the srx but you will have to play with them. i like them my sx handles corners alot better,with them and with a setting of 10 clicks out (hard) or 11clicks in if you are going by 0# being the softest. so play with them and good luck!
