Bravo 94" track
dexter69
maine
so I picked a real nice 83 Bravo only to find out that I need a track. I can't find one anywhere... any help or tips ??
Maim, kimpex has discontinued them. I've called all over the place and everybody says the same thing...even called a guy out in Alberta to see if his supplier has them...said the same thing....discontinued. I just bit the bullet and ordered ones from yamaha for $71ea.
I think the best bet would be to find a used enticer skid (116") for cheap and a 121" track for cheap, then make some rail extensions for $10....I have the measurements to make them that I could give you. I think 27" extensions might be pushing it a bit....you'll probly spend around $400 depending on the deals you can find...then you've got a sweet ride that will pretty much go anywhere! Lol
I forgot to add they've only discontinued the sprockets with the square shaft center hole, they still make the hex hole drivers...but I believe he'll need the square shaft drivers.
