Deereboy
I am hoping someone can help me out. I just bought a 79 SRX that is in real good shape. I have been looking around to find a real good clutch set up.I would be trail riding mostly but would like her to hook up good on the hard packed lake. Any suggestions would be appreciated with springs , weights ect. Thanks
YAMMIEGOD3:16
what clutch first. 3:16 (yammie tony)
Deereboy
it is the original Yamaha primary and secondary from the markings.
Deereboy
I must have said something wrong........Everyone please forgive me. I asked a question because i didn't know the answer. Anyone want to give me a second chance? I have yammy primary and wanted to find a good set up that i can work with. Secondary should be cleaned up and matched up to work with the primary.I would also appreciate being pointed in the right direction to find the springs, weights, ect. Thanks in advance.
Yamaha Nutz
stock "N" weights with just the rivet in the tip with a yellow/orange or red/green primary spring stock secondary set a 120* twist this is a good trail setup that ups the engagement and gets rid of the stock red/white primary spring ...
Deereboy
Are fresh springs available for these?After all the years of sitting in storage, new springs would be good Since i have not removed the primary yet, what weight is stock? Thanks for the reply.
Yamaha Nutz
the 8G9 weight with the "N" mark on them the yellow orange should be available but I know the red green is not you will have to search for them ..............
