Ryan's SXR 700
Hey all
So my dad picked up a rear heat exchanger for his 2002 viper that's been extended to 136.
looks like the heat exchanger he picked up must have been from a SXR or something because the tube diameter is a smaller size then his
cross over pipe that is currently on the sled.
Is there a way to make this work? and would the smaller sized tubing on the heat exchanger hinder the cooling at all of the Viper?
thanks in advance
thanks in advance
super1c
Super Moderator
No it will work fine, you can do one of two things. Buy the smaller diameter hose and heat the end that would go over the viper running board exchangers and force them over the ends. Or as i did just buy a small section of smaller diameter hose and place over the ends of the rear exchanger then slip the viper hose over that and hose clamp them down. Works fine never leaked. The viper cooler lines are a inch and i believe the sx coolers were 3/4"
x2
did tghis in reverse whan i put a srx rear cooler in my 2001 sx500r.
Ryan's SXR 700
awesome thanks guys
so the smaller size hose fits right into the bigger size perfectly?
